Hi all,
I just purchased a Maya44 to mix audio and videos using american audio scratch pro 2 and a Pioneer CDJ 500 mixer.
The problem is that there is a lot of latency, the loop buttons, pitch control, flash cues are in sink with the software and basically not working the way it should be.
When using videos, the fader doesn't even move to switch to the video output on the playing deck. I downloaded the latest cd timecode, installed Maya properly with the same problem. The pitch control on the cd don't even work. the only buttons working on the cd's are the pause and play button.:(
Here are questions:
How can i sink the software with the new hardware and its features. (loop, cues etc..)
Is AmeAudio Pro Scratch 2 compatible with VDJ? if yes, what can i do to map the cd button to match the software
Need some serious help here.
Oumar
Here are questions:
Oumar
Posted Fri 24 Jun 11 @ 1:20 am
this is a pretty small forum mate, you only need to ask once, I answered you question in your other post
Posted Fri 24 Jun 11 @ 3:45 am
