Hi everyone who bothers to read this thread.
I am having a heck of a time getting my headphone cue correct using my NS7 with VDJ.
Here is what is happening...
I start VDJ and everything is fine. I slide the cue fader to the left and I can hear deck one. I slide the cue fader to the right and I can hear deck two.
After a short while, I can only hear Master. no more headphone cueing.
I have tried every setting possible under the options in relation to cue and once i lose cueing, I can't get it back.
I "CAN" spin with no headphones. I don't want to "HAVE TO" spin with no headphones because I can't cue up a track.
Any help?
Any help?
Posted Wed 22 Jun 11 @ 4:26 pm
I had the same problem with my Fast Track Pro where I would lose the headphones. Turned out in my case it was a combination of heat damage and not enough power.
Posted Wed 22 Jun 11 @ 5:00 pm
I have to toggle the switch back & forth a few times along with the fader to get mine right. Try moving the switch to one side, then the fader to the opposite and back a few times. It should only take a few tries to get it, once you do it will become a regular process.
Posted Wed 22 Jun 11 @ 5:41 pm
What switch?
Posted Wed 22 Jun 11 @ 5:49 pm
Hi fam...
I still could use a little help with this as my issue remains unresolved.
Posted Fri 24 Jun 11 @ 7:41 am
see my pm
Posted Fri 24 Jun 11 @ 9:03 am
I had this issue everytime I started up vdj but since the 7.04 release I notice the headphone cueing is corrrect at startup. I used to have to toggle the headphone crossfader back and forth and also the switch directly below it (ch 1-2/ master). After it is set, it is good for the session.
Posted Fri 24 Jun 11 @ 3:10 pm
