Hi there. Does anyone know of any good external VU meters that would work with my Hercules 4mx. The VU meter in vdj is really really bad. Doesnt even show you when your going in the red.
Any help is very much appreciated.
Posted Mon 20 Jun 11 @ 5:53 am
I use an external mixer with mine. One reason is I do not like using the mic input on the controller. it also gives you a meter.
http://www.prosounddepot.com/XENYX-1204USB-Premium-12Input-22Bus-Mixer-Prodview.html
Posted Mon 20 Jun 11 @ 7:22 pm
I also use an external mixer, the RMX sucks when it comes to mic output.....sounds muffled, and very low volume. I just ordered the 4mx, should get it Wednesday. Is the mic output any better with the 4mx?
Posted Mon 20 Jun 11 @ 7:30 pm
prob same as the RMX
Posted Mon 20 Jun 11 @ 7:36 pm
Dang!! Thanks djbojett. Oh well still waiting to play with it once it gets in. Thanks for the heads up!
Posted Mon 20 Jun 11 @ 8:52 pm
Yes it's better, it have more MIC gain ;)
Posted Tue 21 Jun 11 @ 5:05 am
