I'm looking to get a laptop to replace my old desktop and was wondering if this would fill my needs.
Laptop:
IBM thinkpad T60
Specs:
Intel core duo 1.8GHz
3GB Ram
60 GB HHD
Windows XP
Laptop:
IBM thinkpad T60
Specs:
3GB Ram
60 GB HHD
Windows XP
Posted Mon 20 Jun 11 @ 3:47 am
Recent topic covering a very similar thinkpad:
https://virtualdj.com/forums/149289/General_Discussion/Is_this_a_good_deal_on_a_used_Lenovo_ThinkPad_T-61_.html?search=thinkpad&page=1
Obviously based on the specs you are working with there you are not planning on doing video mixing.
Unless you are extremely strapped for cash I wold think you could do better - what is your budget?
Those specs are at least a 3 and most likely 4 year old laptop if not older.
Almost any current laptop will be a better choice.
Posted Mon 20 Jun 11 @ 4:02 am
Laptop:
IBM thinkpad T60
Specs:
3GB Ram
60 GB HHD
Windows XP
Laptop:
IBM thinkpad T60
Specs:
3GB Ram
60 GB HHD
Windows XP
System Requirements
PC Platform
Minimum system requirements:
Intel® Pentium® 4 or AMD Athlon™ XP
1024x768 resolution
DirectX compatible soundcard
512MB RAM
50MB free on the hard drive
RECOMENDED system requirements:
Intel® Core™ 2 or AMD Athlon™ X2
1280x1024 resolution
Multi-channel DirectX compatible soundcard
1024MB RAM
200MB free on the hard drive
Additional requirements for Video mixing:
2048MB (2GB) RAM
ATI™ or NVIDIA® video card w/256MB of Dedicated DDR3 RAM
Video card must support dual-screen output
Mac Platform
Intel® processor
Mac OS X v10.5
1024x768 resolution
CoreAudio compatible soundcard
1024MB RAM
Intel® processor
Latest Mac OS X v10.6.x
1440x900 resolution
Multi-channel CoreAudio compatible soundcard
2048MB (2Gb) RAM
ATI™ or NVIDIA® video chipset w/256MB of Dedicated DDR3 RAM
Video must support dual-screen output
Cheers Mike
Posted Mon 20 Jun 11 @ 4:12 am
As Mike has pointed out the thinkpad will sit somewhere between the minimum and recommended requirements in most degrees and if you are getting it for less than $300 and don't mind having a 10 year old OS on PC then it will work. But if you can swing the choice at the top of this list will run circles around it and have an OS that will be supported far into the future. You will also get much lower power usage and longer battery life with newer hardware due to circuitry advances.
Just a few options:
$399
4GB DDR3 RAM
Intel Core i3-380M 2.53GHz Processor
Windows 7 Home Premium 64-Bit Operating System
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=552735&CatId=4965
$319
AMD Athlon II P340 processor (2.20GHz - 1MB L2 Cache - 1066MHz FSB)
15.6" HD Widescreen CineCrystal™ Display (1366x768)
ATI Radeon™ HD 4250 Graphics
8x DVD±RW DL DVDRW Optical Drive
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=354326&CatId=4965
$349
ASUS K50I-RBBGR05 Notebook Intel Pentium dual-core T4400(2.20GHz) 15.6" 3GB DDR2 Memory 320GB HDD DVD Super Multi Intel GMA 4500M
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220740
Posted Mon 20 Jun 11 @ 4:41 am
the 60gb hdd put me off lol..
Posted Mon 20 Jun 11 @ 5:05 am
