Ok so I have the monitor rca cables hooked up to the djio, however when I go to plug in the headphones to the djio I get nothing. The monitors are working fine and I am able to cue up the next track when I plug the headphones directly into the laptop, however the sound is quite faint. Anybody have any ideas of whats going on here?? Here is a link to the djio that came with the numark mixtrack pro. Thanks
Posted Sat 18 Jun 11 @ 2:25 pm
Please see https://virtualdj.com/wiki/DJIO.html
NOTE: You will need either VirtualDJ Basic https://virtualdj.com/products/basic.html or the full Professional https://virtualdj.com/buy/ to use the DJIO. VirtualDJ Home FREE does not support multi-channel DJ sound cards (Except for a 5.1/6.1/7.1 card built into your PC.)
Posted Sat 18 Jun 11 @ 3:04 pm
Ok, well I have the Virtual DJ LE, I would figure this version would work as it came with the numark mixtrack pro??
Ok so I was able to config the same as the link you sent me. However now the sound is distorted as all F*ck??
Thanks
Thanks
Posted Sat 18 Jun 11 @ 4:01 pm
