Hi, after a couple of weeks saving my Hercules mp3 e2 arrived this morning. After the drivers failed to install, and having to download and install them manually, I then discovered that my version of VDJ only allowed me to play with my controller for 10 minutes.
I then went on to try and install the VDJ Control software that came with my controller, but this was also corrupt.
After 3 hours on desktop control with someone at Virtual DJ, I now have v1.0.5 DJC Edition up and running, but this program looks absolutely awful compared to the home free. Is there any way I can use my controller with a more familiar version of Virtual DJ? any help would be much appreciated, as all the hassle I've had to put in so far is making me wish I'd never bought it, which is fairly gutting after waiting so long for it!
Posted Thu 16 Jun 11 @ 1:19 pm
The LE version of the software that came with your mp3 e2 is specifically dedicated for use with that piece of hardware.
Virtual DJ Home FREE was designed as a personal use software with the functions of Pro (time restricted as you already know) in order to give you a taste of what the software is capable of.
You can have the best of both worlds only if you upgrade to Pro Full. You are entitled to a discount since you purchased the mp3 e2. Simply go to the BUY page, scroll down to where it says Upgrade to VirtualDJ Pro Full, enter your license key that came with your product, and click continue. You will then be directed to the check out page where you can finalize your purchase.
Posted Thu 16 Jun 11 @ 3:36 pm
