Hello fellow DJs
Just got my first controller and its a Mixtrack Pro. I'm as much of a noob as one can get.
So, weird issue i've been having. The volume of the effin' song changes when i touch each turntable. For example, when i touch the left one, that track will get louder, and its not completely silent when the crossfader is 100% on the other track. and the same happens when i tough the right one.
I DONT want the volumes to change when i touch each turntable, and i DO want only one song to be playing when the cross fader is completely on one side...
this is really annoying, and my DJ vocab is very limited so i hope you guys know what i'm talking about. Thanks sooo much!
-one
-one
Posted Wed 15 Jun 11 @ 1:06 am
it came with vdj le
Posted Wed 15 Jun 11 @ 1:51 am
I would try the following:-)
> Deinstall ALL VDJ versions you have maybe installed on your computer and delete the VirtualDJ folder.
Located at C:\User\Documents. Alternative you can move this folder to a USB stick.
> Clean your computer with a tool like CCleaner incl. Registry.
> Register your serial under your account
https://virtualdj.com/users/edit.html
> Load and install your personal copy here:
https://virtualdj.com/download/updates.html
Posted Wed 15 Jun 11 @ 4:10 am
I appreciate your help. It worked find after the uninstall. Werid how things work. Thanks a bunch!
Posted Wed 15 Jun 11 @ 4:31 am
