Hello
I had a minor issue with the controller that I had before so I returned it. I'm stuck in a dilemma on which control to buy now. I'm a beginner DJ Vestex Typhoon or Numark Mixtrack Pro.????
If you recommend any others feel free to do so.
Posted Tue 14 Jun 11 @ 1:28 pm
I was between the same 2 controllers for my first setup. I decided to go with the Mixtrack Pro and it worked out great. The reason I went with the mixtrack was the size I liked the bigger jog wheels and the more spacious layout. The 3 inch controller platters just feel really cramped to me. You wont go wrong either way. Very similar controllers basically personal preference for which one you feel better with.
Posted Tue 14 Jun 11 @ 2:13 pm
You could also try searching for reviews an youtube.
I did the same thing, there are plenty of those comparison vids, which tells you the pro's and con's of the two.
So it's easier for you to decide.
Cheers,
Jivajo
Cheers,
Jivajo
Posted Tue 14 Jun 11 @ 3:22 pm
You can't go wrong with the Numark MixTrack Pro, it is great controller for beginner. Price is wonderful, works great with VDJ, everything works like it's supposed to.
The Vestax Typhoon is good controller, but you get sound interface with MixTrack Pro.
Good luck,
T
Good luck,
T
Posted Tue 14 Jun 11 @ 3:31 pm
