Whenever I go from using the rmx for sound card to using internal sound card, on restart program boot up gets stuck on loading sound engine. Should i configure internal sound card before I shut down when using rmx? I use rmx for gigs and internal for work doing playlists at work. When I leave vdj open and sleep computer I can config, but if I close and sleep this happens???? Anyone???
Posted Sun 12 Jun 11 @ 8:21 pm
try updating your sound card drivers and all apps that affect this config such as the latest vdj and asio drivers and all. it sounds like one of those driver issues. i've got a wifi card that occassionally refuses to recognize any wifi unless i reboot after closing it and leaving it in sleep. updating the drivers helps but i tend to just shutdown and boot fresh as often as possible just to avoid issues.
Posted Sun 12 Jun 11 @ 8:37 pm
Thank you for response. Just tried that and that seems to be the best fix.
Posted Sun 12 Jun 11 @ 8:40 pm
