why doesnt the platters respond with VDJ like they do with Serato itch
Posted Wed 08 Jun 11 @ 3:45 pm
Okay i will try that now. Thanks for the Response
Posted Thu 09 Jun 11 @ 7:12 pm
Now what shoud your jog (bend) and Jog (cue) be set at
Posted Thu 09 Jun 11 @ 7:24 pm
Again, those are by user 'feel' ...
Bend - more to the left then you get less bending when the platter turns - more to the right you get a greater bend % when platters are turned.
Cue - same thing - left is lest speed / right is more speed
Posted Thu 09 Jun 11 @ 8:42 pm
what is ur bend & cue set at
Posted Sat 02 Jul 11 @ 5:13 pm
For faster response, what about checking hid or midilowlatency, does this help or cause issues?
DJ Kavika
DJ Kavika
Posted Mon 04 Jul 11 @ 12:38 pm
There is no such thing as MIDI low latency. Serato simply uses a diffrent protocol to send MIDI information. The name is just something Serato calls it.
And the device has to support HID in order to use HID.
As far as Bend and Cue slider settings it is up to your preference.
Posted Mon 04 Jul 11 @ 1:22 pm
To get better response for your platters with the NS6 you must download the "registry tool" from the virtual dj website under tools i believe. Then you must change the default platter latency from 2095 or whatever it is to 1024. I was going crazy until I saw this on one of the forums myself and I was dancing around my living room when I finally figured it out!
Posted Tue 24 Jan 12 @ 1:26 am
