Sorry, that computer is far too old. VirtualDJ requires an Intel-based Mac running Leopard (10.5) or above.
Please see: http://www.virtualdj.com/wiki/MacOS%20Tiger%2010.4%20and%20PowerPC%20compatibility.html
Posted Mon 28 Nov 11 @ 12:06 pm
Hi
I currently use VD pro on my macbook pro using lion.
I am using a Numark Omni control unit and it wont connect at all.
I have had this problem for 2 months now!?
Is there anything i can do to get my omni control to work?
Posted Fri 02 Dec 11 @ 6:08 am
i have lion with macbook air. there is a problem with equalizer. when levers are exactly in vertical position, if i move one levers there is a CLICKING sound. this is not a problem of my mac because there is the same problem in another mac.. but not with other softwares. i think that virtual dj have a problem with lion.
when i move one levers and i move another levers problem there isn't. it's only when 3 levers are in vertical position centered.
anyone has my problem??
please stuff tell me something about this..
Posted Tue 13 Dec 11 @ 6:20 pm
The only problem i have seen running Virtual DJ on Lion is it seems to take a little more chunk out of my macbook pros memory. I have also seen that when using Virtual DJ in full screen mode, the resolution quality is pretty poor. Otherwise everything seems to be smooth. For more information, visit my DJ site http://www.eastendlideejay.com
Posted Thu 22 Dec 11 @ 10:12 am
Does anyone know a video effect like sonique for mac.
Posted Wed 28 Dec 11 @ 10:23 am
Hey i got a mac version 10.4.11 is there any VDJ edition i can use with my version ?
Posted Wed 18 Jan 12 @ 11:53 am
Please don't post the same or similar messages more than once.
You have also asked the same question in the following topic, where you can find an answer: http://www.virtualdj.com/forums/159596/MAC_Version_Technical_Support/Hey_Mac_people_i_need_help___.html
Please also don't hijack topics by posting a message that is not related in anyway. Your question has nothing to do with using VirtualDJ with MacOS Lion.
Posted Wed 18 Jan 12 @ 12:20 pm
I have a hercules Dj control e2 and unfortunately the virtual dj djc is not working. Every time I try to use it I get a report of skin problem. How can I solve it!?
Posted Mon 05 Mar 12 @ 3:00 pm
Please see our FAQ pages:
http://www.virtualdj.com/wiki/Invalid%20Skin%20Error.html
If this doesn't help resolve the issue, please contact support:
http://www.virtualdj.com/contact/index.html
Posted Tue 06 Mar 12 @ 5:02 am
I just bought a new macbook pro late 2011 laptop. I can't get it to recognize my devon dn-x 1600?
Has anyone had this problem?
mac os x version 10.7.3 core177
Posted Mon 12 Mar 12 @ 10:10 pm
hi there everyone,i have jus bought a mac book pro n downloaded the virtual dj 7 home free edition.the problem i m facing is when ever i scan my songs for the bpm it shows me 123 (bpm) for all the songs.how can i resolve this prob?plz gv me a solution to this prob and email me at ****@****. thx a lot
[Sorry, E-mail addresses and other contact details are not permitted for unlicensed users.]
Posted Sun 25 Mar 12 @ 6:00 am
Posted Mon 26 Mar 12 @ 5:35 am
KANIFORM wrote :
Since I installed Lion my version of Virtual DJ Pro crashes before it opens. I've tried uninstalling and reinstalling and making sure everything's up to date. Any ideas / anyone else experienced this?
I just installed the Virtual DJ Pro on my new Lion and it crashes when I try to adjust the preferences. It also cut off all sound to different channels. Im freaking out, I have a wedding reception next weekend. Somebody help!
Posted Fri 27 Apr 12 @ 9:01 pm
Hi Guys,
I've recently upgraded to Lion. I have a 13 inch MacBook Pro and I've had no problems until now. I'm noticing with Lion though that my CPU usage is always very close to 100%, which never happened on Snow Leopard. Any fixes/suggestions?
Alex
Alex
Posted Sat 12 May 12 @ 3:52 pm
Make sure that you have not maximised or resized the skin.
Please see: http://www.virtualdj.com/wiki/Performance%20Issues.html
Posted Mon 14 May 12 @ 5:45 am
good performance video with 1280x1024 videos
bad performance with 1920 videos...
what issues ?
what issues ?
Posted Sun 24 Jun 12 @ 12:14 pm
Has anyone used generic 5.1 or 7.1 USB sound devices w/ Lion? Is CoreAudio the only means to run VDJ for the mac?
Posted Mon 02 Jul 12 @ 2:22 pm
I am having a major issue with it. When I start up VDj it locks up and never starts up. So I have to reboot my iMac, then start it up.
Posted Fri 13 Jul 12 @ 10:56 am
Hi, the new relase Mountain Lion for Mac, is compatibility with the DDJ ergo and Virtual d.j. 7 LE? Thanks
Posted Fri 27 Jul 12 @ 8:30 am
hi guys
i have had problems with the NI DJ Audio 8 card
but if i installed the Beta driver from here
http://download.native-instruments.com/um/audio_8_dj/Audio_8_DJ_251_Mac.dmg?token=d077e5549cfd55f3494cc6f7454e30b5&tstamp=501fa843
it works for me
BUT now the card output is more quiet than before
did some of you noticed that too?
it works for me
Posted Mon 06 Aug 12 @ 7:34 am
