quick one guys..will this unit work on my back up mac 10.5.8 cheers
Posted Mon 06 Jun 11 @ 3:25 pm
Mac minimum requirements
1.5GHz CPU or higher / 512MB RAM
Mac OSĀ® 10.4 / 10.5 / 10.6
Yes it will if it meets the above system specs. Cheers
Posted Mon 06 Jun 11 @ 8:14 pm
Providing that your backup computer is Intel based with MacOS 10.5 or later installed then you should not have any problems. You have 10.5.8, so your O/S is OK.
MacOS Tiger is an obsolete operating system and is no-longer supported by VirtualDJ or Apple.
PPC (PowerPC) processor is also no-longer supported by VirtualDJ.
Your computer needs to meet and preferably exceed the recommended hardware specification at the bottom of the following page: https://virtualdj.com/products/virtualdj/
Posted Tue 07 Jun 11 @ 7:33 am
