Hey guys
I am a beginner to DJ'ing, and have done a couple of mixes on VDJ7, it's a great piece of software. However, I am now looking at buying a couple of CDJs and a mixer. I was looking at buying the Numark iCD DJ in a Box, however I don't know if they are compatible with VDJ7 and will be able to connect to my MacBook Pro.
Also, I wanted to know if they were actually any good for a beginner, I have around £300-400 to spend, so they come in at a good price, and seem alright for me at the moment.
Any help with those 2 bits will be appreciated.
Thanks!
Thanks!
Posted Sun 05 Jun 11 @ 6:31 pm
Hercules RMX - http://www.djstore.com/item/startersystems/herdjconsolermx.htm
Vestax Typhoon - http://www.djstore.com/item/startersystems/vestyphoon.htm
Numark iDJ3 - http://www.djstore.com/item/startersystems/numidj3.htm
All come with VirtualDJ LE.
The box set you mention would require you to purchase VirtualDJ PRO Full and a 4-IN/4-OUT sound card to do a timecode setup.
And even then I would not recommend using that particular box set in a timecode setup.
Posted Sun 05 Jun 11 @ 9:42 pm
Thanks for the reply man, really helps.
Are there any decent CDJs on the market for the price range I have that I can use with VDJ?
Posted Mon 06 Jun 11 @ 8:45 am
