Hello All,
So I decided to put my RMX to good use while at home so grabbed a pair of NDX 400s and wanted to experiment with timecodes. Downloaded the time codes, set up everything, (been searching the forum for set up info) got the right deck working, can't seem to get the left deck working. Tried switching CDs, I have the left deck into channels 1&2, right deck 3&4, when I switch the config through VDJ the left one works, the right one doesn't. Am I missing something, take it easy on me, first attempt at this. Thanks in advance for the info. Also I burned the regular timecode. Should I have burned the one for pro players?
Posted Sun 05 Jun 11 @ 10:19 am
Wow! Can't believe I posted this 5 days ago, no response from anybody. Where's the love?
Posted Fri 10 Jun 11 @ 1:15 pm
might wanna check if you have one of them RCA leads plugged into output on the RMX instead of input
Posted Fri 10 Jun 11 @ 1:53 pm
make sure you have the inputs of your RMX set to Line... THIS MAKES A BIG DIFFERENCE.. each input has it's own switch.. It wont work if it is set wrong
Posted Fri 10 Jun 11 @ 3:44 pm
Appreciate the response, I will double check the it the next time I set up.
Posted Mon 13 Jun 11 @ 2:24 pm
