I have the Hercules Dj Control Mp3 e2 and use Virtual DJ Pro with it. My friend got it all installed and working for me with the sound card allowing for me to monitor a second song when bringing it in on Deck B however there was a problem and I had to reinstall myself. I can now not get the headphones linked up with Deck B and Virtual DJ is playing both the songs out loud on the speakers. I'm not sure if it is a problem with my windows settings or the virtual dj setting but i have followed what is said in the User Manual so i will list both:
Control Panel - Sound
Selected "Speakers USB Multi Channel Audio Device Working"
When I configure it is set to 5.1 Surround and when tested only plays on the speakers.
Virtual Dj Pro
After pressing config the settings are set to the following, as suggested in the User Manual:
Inputs: None
Outputs: Headphones
Master: Front Output/Headphones Rear Output
Sound Card 4.1 Primary Sound Driver
Had this problem for a while and feel like giving up on the decks so any help would be greatly appreciated, cheers :)
Virtual Dj Pro
Inputs: None
Outputs: Headphones
Posted Fri 03 Jun 11 @ 2:45 pm
anyone?
Posted Sun 05 Jun 11 @ 11:16 am
ebay then if anyone wants them
Posted Tue 07 Jun 11 @ 12:55 pm
