I've been trying to map my Numark Total Control to control 4 volume faders in VDJ. My aim is to map:
pitch fader left = volume deck 1,
volume fader left = volume deck 2
volume fader right = volume deck 3
pitch fader right = volume deck 4
I have been playing around for hours trying to work out how to do this with VDJscript trying various things, thinking I'km almost there and then totally messing it all up.
I really have no clue how to do it.
Does anyone know if this is at all possible or do i need to give up with this?
Thanks
Thanks
Posted Fri 03 Jun 11 @ 9:58 am
If you want to do that it needs to be scripted like... deck 1 volume
but you can use the (EDIT whoops) device_side left/right code to change which deck your total control err controls :)
https://virtualdj.com/forums/135723/Hardware_Technical_Support/Advanced_Mapping_Verbs_Swap_Decks.html
Posted Fri 03 Jun 11 @ 10:13 am
Map the pitch slider (PITCH) to the following:
device_side 'left' ? deck 1 volume_slider : deck 4 volume_slider
Because pitch sliders are often inverted, you may need to use the following instead of the above:
device_side 'left' ? param_invert & deck 1 volume_slider : param_invert & deck 4 volume_slider
Match the volume slider (VOLUME) to the following:
device_side 'left' ? deck 2 volume_slider : deck 3 volume_slider
Posted Fri 03 Jun 11 @ 10:18 am
Thanks a lot guys, that has done the trick for now.
Going to map a few other functions now, but hopefully it will be ok, I think I've got the idea (famous last words).
Cheers
Cheers
Posted Fri 03 Jun 11 @ 10:32 am
Im having Difficulty Customizing the mappers
example effect select and eq kill high etc....
any help would be greatly appreciated
Posted Fri 03 Jun 11 @ 12:12 pm
You should start your own topic and say what you want to map it to eg, knob, button etc...
Posted Fri 03 Jun 11 @ 12:34 pm
