My DN-HC1000S has decided to stop lighting up.
The only thing that has changed with my system is that I have added 2 CDJ 850'S. I have tried unplugging the CDJ's to see if that makes a difference, plugging the HC1000 into another USB port an back again. Still no lights, it is still working fine though just not lighting up.
Posted Sun 29 May 11 @ 2:02 pm
SOLVED!!
In the heat of the moment, I must have inadvertently switched to one of the 3 midi channels not being utilized by VDJ.
FIX!!
If you push Shift + Browse or History or Prepare the HC1000S will feel like its dead and not respond to anything, unless you push Shift + Files to return to native midi channel 1. (both Cue1 LEDs light up)
FIX!!
Posted Sun 29 May 11 @ 5:14 pm
