Hello,
I have made a custom mapping with mc-6000. The problem is that it seems that the some default mapper functions still gets triggered even though I have mapped them to something else. For example I have mapped SEARCH- and SEARCH+ buttons to key_move+-1 when SHIFT is pressed at the same time:
SEARCH- = var$shift ? key_move -1 : goto -1
SEARCH+ = var$shift ? key_move +1 : goto +1
Originally pressing shift+search buttons will toggle between vinyl and bend jog mode and it still happens! When I press
shift + search+ , the key moves 1 up but ALSO jog mode toggles to BEND. What is this? I don't want it to do so.
I seem to have this problem with some other buttons too, but only few of them, not all. How do I prevent original mapper functions to be triggered on mc-6000?
Posted Tue 24 May 11 @ 6:16 am
This is because SHIFT with these buttons are hardware mapped in the MC6000 firmware to toggle the jogwheel touch sensor on/off.
Even if you change the mappings, they will still perform this function, but VirtualDJ will then not match the same state as the hardware.
This is a hardware/firmware feature and cannot be changed,
Posted Tue 24 May 11 @ 7:42 am
Okay, is there some other firmware mapped functions? At least pressing SAMP button always toggles between cues and samples so mapping it to something else causes trouble. I would like to know the rest....
Posted Tue 24 May 11 @ 11:21 am
The following have special functions in the firmware:
SHIFT+PITCHBEND -/+ = Turns pitch lock on/off (Firmware-based 'soft' takeover for pitch sliders when changing between decks)
SHIFT+SEARCH -/+ = Pitch bend mode/vinyl mode
DECK = Toggles MIDI channel on left or right side of MC6000 to control alternative deck
SAMP = Toggles buttons between hot cues or samples 1-4.
SHIFT+BROWSER/SAMPLER/EFFECTS/RECORD = Changes MIDI channels of the MC6000 (Be careful not to press this by accident - MC6000 will only work with VirtualDJ on the default channels 1-4 - Press SHIFT+BROWSER to revert back to these.)
Posted Tue 24 May 11 @ 1:22 pm
