I'm using an all in one's mixer as an external mixer with VDJ 7. The only problem is that it sends out the audio signal all to one side. Meaning i can't use the other channel.
http://www.djcity.com.au/products/djcapsule-dj-cd-player-dj-mixer-complete-sd-mp3-scratch_1529.html
I use this, along with an internal sound card that comes with the Asus M4A87TD evo mobo. Which apparently has 8 audio channels, but i'm not so sure..
http://techwiki.hardwarecanucks.com/product/2NTEyNzI5NzIwMA/Asus-M4A87TD-USB3/
Any help regarding this will be greatly appreciated
Posted Sun 22 May 11 @ 10:25 pm
What you need is a professional multi channel ASIO sound card.
Sound built into motherboards is only ever intended for low end domestic consumer use, not DJing.
The chip itself may have 8 channels, but unless the MB has 4 separate stereo outputs, you won't have access to them for connections.
You don't need to spend a fortune. Just look for ASIO and make sure it has four outs (i.e. two stereo channels).
Posted Mon 23 May 11 @ 6:00 am
