I use Virtual DJ Pro with an HP laptop, Windows 7, and connect via USB to two Pioneer CDJ-400 players
Until a couple weeks ago, no problems - the left player would say 01 on the display, and I could use the player to control, and the right would say 02, same functionality
Suddenly one day I booted up, and now both players say 01
I can use Cue and pause and pitch control, etc, but only for 01
The software functions perfectly otherwise - if I stay strictly on my computer screen with the mouse, it all works fine with mixer on separate channels, just does not allow me to use both decks in a physical sense
As a test, I installed on my other HP laptop, also with Windows 7, and it works perfectly fine
My instinct says this is a Windows issue, and maybe a driver mapping issue?
Just want to know if anyone has any insight into what i need to re-install or revise, is it a Windows problem? A USB driver problem? Corrupt Virtual DJ problem?
Just don't want to lose my Virtual folders and stuff like that, so any info from anyone is appreciated
Thank you in advance.
Posted Wed 11 May 11 @ 10:09 pm
Press EJECT on CDJ to swap decks.
In case you have changed the default mapper and EJECT does something else, goto Config->Mappers select CDJ from the drop down list and choose Mapper Options to assign each CDJs to the decks you wish.
Posted Thu 12 May 11 @ 11:38 am
thank you so much! config mappers worked perfectly.
Posted Thu 12 May 11 @ 12:10 pm
