I have a MacBook Pro with an i7 core. I'm using the newest full pro version of VDJ. I have a Numark Mixtrack Pro and an M-audio Trigger Finger. Both devices will work, but not when plugged in at the same time I can't use them both.
I'm trying to use the Mixtrack to DJ and the Trigger Finger for samples and effects. Any tip? Or anyone know why they only work one at a time? Thanks!
Posted Tue 10 May 11 @ 12:32 pm
I know with some MIDI kits you can change the MIDI channel. Not sure if this can be done with these but worth looking into.
Huey
Huey
Posted Tue 10 May 11 @ 1:02 pm
If both devices are connected , what do you get as listed Devices on Config->Mappers ?
Posted Wed 11 May 11 @ 10:10 pm
I see:
Numark Mixtrack Pro
Simple MIDI Wrapper
Keyboard
I tried messing around with the simple MIDI wrapper one but still couldnt get the trigger finger to do anything
Numark Mixtrack Pro
Simple MIDI Wrapper
Keyboard
Posted Thu 07 Jul 11 @ 7:02 pm
Your probably better off asking in the MAC forum, but I think I remember reading somewhere that you need to rename the midi devices in your mac settings somewhere as they don't have any drivers, which a lot of the mappers use the driver name to distinguish the device, if the driver doesn't match up the mapper and there is no SysEx id, the mapper is used on any unidentified connected device... er I think LOL
Posted Fri 08 Jul 11 @ 1:14 am
