Hi Everyone,
I was doing a charity event today and I was having problems with my RMX and my laptop.
All of a sudden, the rmx would stop working. This happened several times
I had to close VDJ and unplug the rmx and then plug it back in. It would then be fine for about a hours or so and then happen again.
Any advice on how to fix this would be great
many thanks
Justin
many thanks
Justin
Posted Fri 06 May 11 @ 1:52 pm
well it's hard to help you because we need some info
what operating system ? how full is your C: ?
sounds like something in the background coming on and causing a problem , but could be a number of other things
how much ram ? how many processes running?
when was the last time you defragged or cleaned the registry ?
does yer girlfriend have a sister ?
uninstalling and reinstalling the RMX may do the trick
Posted Fri 06 May 11 @ 2:48 pm
I have 8 gigs of ram.
Windows 7 64 bit
core i7
5gb video card
C: drive has loads of room on it. Computer is fairly new, 3 months old.
will try unistalling it and then re installing it and see what happens.
I wasnt sure if there might be a setting for USB timimg out or something
And no to the sister by the way lol
Windows 7 64 bit
core i7
5gb video card
Posted Fri 06 May 11 @ 3:16 pm
Tried new driver and still same problem, any other advice please
Posted Wed 11 May 11 @ 12:11 am
Check the following document, specially the section on USB:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
Posted Wed 11 May 11 @ 6:39 am
Before getting too carried away, it helps to know how your system works. Here's a thread to help you sort out any background processes and optimize your system: https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
Best of luck
Best of luck
Posted Wed 11 May 11 @ 8:09 am
The only program I have on this computer is virtual dj. I have dedicated this computer just to dj ing, so I do not believe it to be a background program issue.
It's a clean install aswell, got rid of all the basic stupid programs that come with new computers
Posted Wed 11 May 11 @ 4:28 pm
had the same problem while playing at a wedding, turn out it was the usb cable that was bad, try changing yours and see what happen.
Posted Wed 11 May 11 @ 6:13 pm
