I just bought a DN HC4500 and DN X900...
I'm running on Virtual DJ...
I don't have speakers yet which may be the answer to my problem but I have my 4500 connected to my mixer from line 1 to line 8 in the mixer and both songs play on one channel and when i connect line 2 from my controller to any other line on the mixer like 6 it doesnt work or play any music. Only only one line works and both songs come out through one channel on the mixer. I dont think it's suppose to be like this cause if i have line 1 and 2 on my controller connected through two different lines on the mixer, shouldn't one song play on one channel and not both???
How should i set up the INPUT, OUTPUT and SOUND CARD option in configuration so it works properly cause it doesnt say how to set it up to my devices
Posted Thu 05 May 11 @ 12:42 pm
You need to install the ASIO drivers for the HC4500 (if you haven't already) then set the VDJ config to external mixer and ASIO sound, and choose which ASIO channels to use for each VDJ deck.
Posted Thu 05 May 11 @ 12:56 pm
i did that but when i connect my controller to my mixer through one out put both songs play when it should only be one, and when i plug in the secong line to another channel on the mixer it doesnt work at all
Posted Thu 05 May 11 @ 1:01 pm
how do i choose asio channels to work with the 2 decks?
Posted Thu 05 May 11 @ 1:14 pm
You have to go into advanced config and set it up there.
Huey
Huey
Posted Thu 05 May 11 @ 2:03 pm
Is there a guide on this forum that can help me setup my dn hc4500 and dn x900 to virtual dj?
Posted Thu 05 May 11 @ 4:04 pm
