Topic: Serious Problems with v7.03 I need help with.
(1) periodically during the night the pitch just gets a mind of it's own and makes the songs sound like sh*t as the pitch keeps going up and down constantly throughout the song.
(2) It will not load the whole video, only about 15 seconds at a time and sometimes it plays all that before it loads more so there is a "gaps' of dead air at various points in the song.
(3) Current video playing will freeze until the video is loaded into the other deck.
I am having all three of these problems on my home test computer, both club computers and my laptop (which is the one I perform from). I never had these problems on my laptop or hiome computer with 6.12 (which I rolled the lappy back to for my shows).
Any help greatly appreciated as I would like to start using the 4 deck feature of v7.
Posted Wed 04 May 11 @ 1:20 am
You should post this in technical support. Sorry I don't know how to fix your issues.
Mate...i dunno about anyone else, but i was having issues in 7.0.3 and rolled back to 7.0.2 and it *seemed* to get sorted. The issues weren't quite the same but the rollback seemed to help.
I also even tried rolling back further to version 5 as it seems that between 5 and 7 there were many changes made, from video and sound engines to everything else.
I may be wrong, but initially i'd go back to 702 and see what happens.
I don't know how to solve your issues but i did have a similar issue with video not loading all the time. I did get a warning box and it turned out i had memory leak issues..i've got a thread on the board somewhere. Don't get me wrong...i had to scour the forums and the net and managed to sort the issue myself but i'm not sure if this is slightly different to what you're getting.
If it's only loading 15 seconds of a track at a time or there is a freeze on the other deck whilst loading, then i'd say it was a memory issue anyway. Do you have DJCel's reg tool? You can assign video memory and stuff which is kinda neat.
I'm not a computer expert though. i've historically built all my machines myself and recently built a new 7 machine but am only 70% with the actual inner workings of them i'm afraid.
I hope you get it sorted. There's nothing worse than feeling a bit silly at a gig!!!
Keep spinnin'...(",)
P
This particular problem I originally posted over 2 years ago https://virtualdj.com/forums/119804/General_Discussion/Video_Freezes_Until_New_Video_loads_in_6_04.html?search=dj-e-lectric&page=1
when I had it with 6.04. Never heard of any solution but for me it dissappeared with the next version and haven't had the problem since and the lappy has been the same since August of 09....so whatever caused it in 6.04 seems to be back in 7.03.....I also noticed in the config for 7.03 there is no longer the option for "Max Load>ALWAYS", now you just need to set a number. Anybody know what that number should be to make sure you are always loading the complete file?
