I recently bought a Hercules DJ console RMX and when i have my speakers plugged into the 1-2 jack it only will play through one speaker. But when I plug the speakers into the headphone jack it works fine with both speakers.
I'm using windows 7 32 bit
if anyone could help me out I'd appreciate it a lot :)
Posted Tue 03 May 11 @ 1:58 am
Make sure there in the 1-2 sections and correcty inserted, To me that is the only problem.
Posted Tue 03 May 11 @ 5:00 am
could be your balance control as well.
Posted Tue 03 May 11 @ 6:05 am
@ Draydox
I'm guessing you are using computer speakers with a mini jack connector to which you've added a 1/4' adapter, and connecting it to only one output of Output 1/2 ?
Since you are using a stereo connector in a mono output, you will only get one speaker working.
I would suggest using a mini jack to RCA adapter:
http://images.bizrate.com/resize?sq=273&uid=1922016176
The RCA output level will be more appropriate for your speakers.
Posted Tue 03 May 11 @ 7:20 am
