Hi everyone
I need to map my effect buttons on my 4mx so they will activate other effects than the original ones which include the skin .
If you can provide me with a step by step instruction I would be so happy if not that's ok too ! or if there is a forum or something about this Please give me the link cause I can't find any on google !
Posted Thu 28 Apr 11 @ 12:05 pm
Sorry, the software that you received with your DJ Console is a free limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.)
To be able to use custom skins, effects and much, much more you will need to upgrade to the full VirtualDJ Professional. Your VirtualDJ LE entitles you to a significant discount off the cost of upgrading. To receive this, please go to https://virtualdj.com/buy/ and enter your software serial number in the box provided at the bottom of the page.
You can also try out Pro features in VirtualDJ v7 Home FREE by going to https://virtualdj.com/download/free.html - This software will allow you to test your MIDI controller with it for 10 minutes at a time before reverting back to internal mouse and keyboard control only.
For basic mapping instructions, please see https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
NOTE: In VirtualDJ LE, you can choose from a limited selection of effects, loops, hotcues, etc. Click on the down arrows next to each effect button on 4-Mx skin to change the assigned function.
Posted Thu 28 Apr 11 @ 12:11 pm
