can i connect a numark cdn 88 with a denon mixer to serato
Posted Tue 26 Apr 11 @ 9:20 am
sry no support! this is a vdj forum
Posted Tue 26 Apr 11 @ 9:48 am
This forum is for general DJ questions as well as just for VDJ.
I'm not a timecode user but do you not need a Serato box as well?
Keith
Keith
Posted Tue 26 Apr 11 @ 9:53 am
If you wish to use timecode CD's with VirtualDJ then you will need a sound card designed for timecode use with atleast 4 inputs and 4 outputs, such as Hercules DJ Trim, Native Instruments Audio 4 or 8 DJ, Rane SL1 (PC only) or SL3, etc.
You will also need the full VirtualDJ Professional: https://virtualdj.com/buy/ - Timecode can be tried out for 10 minutes at a time in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
You can create timecode CD's yourself using the timecode audio file that can be downloaded from https://virtualdj.com/products/timecode/cd.html
Posted Tue 26 Apr 11 @ 9:57 am
i have the professional software for vdj nd i have serato too
Posted Tue 26 Apr 11 @ 10:57 am
So do you want to use VDJ or Serato as your initial question is a bit ambiguous?
If you have VDJ Professional please register your serial number on this site to get the latest updates and plugins available.
Keith
Keith
Posted Tue 26 Apr 11 @ 11:22 am
