I have lost my key lock, both on the interface and my controller, which is a DMC 2. It is not my controller, because it works on my other machine, which is Vista. I am using 7.03 but even when I went back to 7.02, no good. This is my gig machine which is XP, and it worked fine before. The mapper is set correct. The only I did different is, I used the registry tool just to see if "load video faster" did anything. Any help would be appreciated. As I said, it worked fine before.
Posted Mon 25 Apr 11 @ 7:18 pm
Config->Performances..
make sure Master Tempo is not set to Purescratch(no master tempo)
Posted Mon 25 Apr 11 @ 10:14 pm
Yo, you are the man. I forgot I was playing around with that. Done. Thank you.
From now on, I will write down any changes I do, because I can't remember everything.
Posted Mon 25 Apr 11 @ 10:33 pm
