Hi,
Got the following setup:
- Two Stanton's T120 decks
- Numark X9 mixer
- Hercules RMX
What I want to do is use the Hercules as a soundcard to record the music I play with the external mixer (Numark X9) and two decks.
Any suggestions, I can't figure out how to set it up.
Thanks in advance.
- Numark X9 mixer
- Hercules RMX
Thanks in advance.
Posted Sun 24 Apr 11 @ 10:38 am
If you are already using the Rmx as a soundcard with VDJ, it would be difficult to use it at the same time for recording the mix of it all.
A better option would be to use your computer onboard soundcard.
Posted Tue 26 Apr 11 @ 7:52 am
