Hi guys.
I'm as much as a novice as a novice can get. Just working my way round VDJ and it's a great piece of software. I've mixed a few songs together and I think they're pretty good.
Anyway, i've been setting up cue points on both songs to help me blend the next track. I have both songs at the same BPM so that saves trouble there.
Now, please correct me if I'm wrong but when the two separate cue points meet I press play and then quickly press "Sync" to get the beats matched up.
Now what I'm asking is is there any sort of feature that automatically plays the next song when the cue points meet? I'm not looking into live DJ'ing just creating some mixes so don't shoot me for cheating!
I'm asking this as its hard to press play at the correct exact time and it sounds awful until you keep pressing "sync" until it matches. I've set the cue points up to the exact beat so it would blend in more smoothly if there was a feature like this.
Thanks guys!
Thanks guys!
Posted Sun 24 Apr 11 @ 4:46 am
Does this make sense to people?
Posted Mon 25 Apr 11 @ 8:52 am
There's a few options for you to look at in the user manual >>> https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20User%20Guide.pdf
1) You can try the beatlock function to get the timing on your mix synced together. When you hit play with beatlock engaged it will auto sync to the other deck.
2) You can use automix mix points to have the tracks automatically mix together at specified points.
Read the manual and play around with the software and you'll see what I'm talking about.
Hope that helps.
AC
Hope that helps.
AC
Posted Mon 25 Apr 11 @ 7:00 pm
Posted Mon 25 Apr 11 @ 7:45 pm
