How do you make the microphone work with mixtrack pro? I'm just using the LE version on VDJ. Thanks!
Posted Fri 22 Apr 11 @ 9:23 am
u gotta use virtual dj 7 pro in order to use the mic!!
Posted Mon 16 May 11 @ 8:49 pm
nope, its actually built in to the hardware, and is not part of the USB soundcard
Posted Mon 16 May 11 @ 10:04 pm
Just plug your mic into the Mic port on the front of the mixtrack pro and it will come through your speakers....U can't record your voice or anything with VDJ because it doesn't interface with the software it is strictly hardware based.
Posted Tue 17 May 11 @ 1:07 am
