Forum: Old versions
Topic: Trouble recording audio mixes
Having an issue here recording audio mixes using Virtual DJ Pro 7. I'm using 2 Pioneer CDJ 900's, 1 Pioneer DJM 5000 Mixer & Macbook Pro. I have a RCA to 1/8 cable running from the "record out" on my mixer to the Input on my Macbook. I've seen other threads saying I need to set it up in Advanced Configuration but still can't get it right.
Problem is both of my CD decks are running through the same channel on my mixer. I tried a variety of configurations (some I've listed below) and keep having the same issue. Any thoughts on what I need to have the settings on? I plug the CDJs into my laptop directly via USB (they have soundcards built in). Do I need to maybe adjust something on Mac audio settings? Any help would be greatly appreciated. Thx.
Deck 1 - Pioneer CDJ-900
Deck 2 - Aggregate Device
Record Loopback - Built-in Input
Deck 2 - Pioneer CDJ-900
Master - Pioneer CDJ-900
Posted Thu 21 Apr 11 @ 9:36 pm
I'm not completely sure, but I think you need to buy either the Pro Basic or Pro Full version to be able to output the decks separate. A little more info is in:
https://virtualdj.com/products/comparison.html
And please try not to cross post the same question all over the place.
I'm using the Pro version. 7.0.2 Pro.
I think it should be possible to do with neither advanced config in VDJ nor aggregate devices in Mac Audio settings. But let's try both...
Try:
* In Mac Audio setttings, create an aggregate device wich contatins the both CDJ's. It should have four outputs.
* In VDJ advanced config, assign Deck 1 to aggregate device/output 1 & 2, and Deck 2 to aggregate device/output 3 & 4. (Record Loopback as before.)
Curious question: Why don't you use the DJM 5000 as sound card/output device?
why not record straight from VDJ?
Are you using external sound fx?
So I just signed up for this and I love it. Only thing is Im not sure how to save my mixes after I've recorded them. Any suggestions?
Hello,
How can I get the mic sound to record on VDJ 7? The music records great but the MIC output will no record.
tadaryl wrote :
Hello,
Do you have any external hardware? (MIDI controller, sound card/IO, mixer)
How its going. I have a denon dn mc 6000. I have the Mic going through the denon controller. The sounds come out the speakers. It just wont record. I'm assuming i need to go to advance configuration. Is that correct?
I think the advanced audio config is easiest to fiddle around with in this case. I've never worked with a dn-mc-6000 or other controller with built in sound-card, but I downloaded the manual a few minutes ago and tried to "swim in the dry".
As far as I can read... (from page 17-18 in manual)
On the dn-mc-6000:
* Turn on the POST switch ON in the MIC settings area at the left side.
* Select REC OUT/MIC output mode in the USB area in the back.
In VDJ advanced audio config:
* Outputs matching your previous config.
* "Record loopback" from your Denon input channel 1&2.
Use the MIC ON 1 and MIC ON 2 switches on the dn-mc-6000 to activate the mics.
Hope this helps!
On the dn-mc-6000:
Hope this helps!
Hello Matts, I'm still having the same issue because vdj will not let me config in advanced while using the denon mc 6000 mixer. I will still like to thank you for trying.
