Hello i have recently bought a audio 8 dj usb soundcard. Im using a desktop with windows xp sp3...so which is the best driver ? Ive read that the latest drivers give problems.
So anyone who uses windows xp sp3 and audio 8 dj can tell me which version drivers uses and have better performance and stability...
Thanks in advance....
Posted Mon 18 Apr 11 @ 3:27 am
Well I don't use xp, I'm running Vista. I use the drivers that came on the disk with the audio 8. I tried the new drivers and had nothing but problems.
That's my experience
Huey
Huey
Posted Mon 18 Apr 11 @ 7:56 am
Short of finding someone that has those specs., I would start by using the latest drivers and go back from there one at a time if it doesn't work properly until it's right....
Good Luck,
Joey...
Posted Mon 18 Apr 11 @ 9:04 am
beatbreaker1; Can you tell me what version are ? I suppose 1.1.0 because i have to download the driver from internet
Im trying to find people with audio 8 dj and windows xp sp3... and looking for they help and experience ( if desktop better).
Thanks
Thanks
Posted Mon 18 Apr 11 @ 9:45 am
Driver Version 2.0.10
Firmware 24
I'd go with Joeys option, its only gonna take a matter of minutes to figure out if that version is gonna work or not. You can also roll back or just delete it if it doesn't work.
Good Luck and let us know what worked
Huey
Firmware 24
Huey
Posted Mon 18 Apr 11 @ 9:58 am
No one else has audio 8 dj with windows xp and virtual dj ??
Posted Wed 20 Apr 11 @ 5:16 am
Driver version is 2.1.0.01. I am using windows 7 64bit.
You're going to have a hard time finding someone using XP and an audio 8 my friend.
Posted Wed 20 Apr 11 @ 4:07 pm
Hi,
Im running the save Setup. VDJ + Win XPsp3 + Audio 8 DJ.
Would you mind tellming me which Driver Version you finally used?
Thanks.
Thanks.
Posted Sat 26 Nov 11 @ 9:46 am
Firmware 24
Huey
Firmware 24
Huey
Posted Sat 26 Nov 11 @ 9:48 am
