I just a got a new laptop and the specs are as follows: windows 7 64 bit, intel core i7 processor, 6 gigs ddr3 ram, 750 gig hd, nvida geforce gt525m with 1gb gddr3 video ram, directx 11. My controller is the numark ns7.
I have no problems playing audio, very sweet actually... no latency and very low cpu usage.. however, every video I load freezes... the audio portion of the video plays well but the video freezes and the cpu usage stays low as well... I have been searching the forum for solutions but havent found any.. I need your help as I play video 3 - 4 times a week using vdj.....Thanks in advance guys...
Posted Sun 17 Apr 11 @ 5:52 pm
Posted Sun 17 Apr 11 @ 6:10 pm
Is it the video on your screen, or the screen that the client sees, or both? Are you using 7.0.3 version?
Posted Sun 17 Apr 11 @ 6:12 pm
Freezing on both screens and I am using 7.03..thanks
Posted Sun 17 Apr 11 @ 6:22 pm
Check the link listed above. It's quite long, but it may help. Let us know.
Posted Sun 17 Apr 11 @ 6:33 pm
Thanks for your help guys... I think I may have got it sorted... It was not a problem with virtual dj apparently.. I changed a setting in my nvidia control panel....
- the graphics processor in the 3d settings was set to "auto select"... I changed it to "high performance NVIDIA processor"
- in the set physx section I selected the geforce card instead of auto select
- I did not change anything in the registry tool
I will post feedback after more extensive testing but I have had no freezing or other issues since making these changes... my cpu hardly moves... loving it so far...
Posted Sun 17 Apr 11 @ 7:52 pm
Ok, I have been reading my butt off and still can not tell if this issue have been fixed or not. Honestly it went away for me when VDJ6 came out but when I upgraded to VDJ7 it started again. I stopped doing video for a while but know the demand for it is coming back in my area. Here are all my specs. I use a Hercules MKII as a controller. I made sure all my drivers are updated for my video card and the MKII.
HP DV7-2270us
Processor Intel Core 2 Quad Q9000 / 2 GHz
Multi-Core Technology Quad-Core
64-bit Computing Yes
Data Bus Speed 1066 MHz
Cache Memory
Type L2 cache
Installed Size 6 MB
RAM
Installed Size 4 GB / 8 GB (max)
Technology DDR3 SDRAM
Form Factor SO DIMM 204-pin
Configuration Features 2 x 2 GB
Storage Controller
Type Serial ATA
Serial ATA Interface Serial ATA-150
Storage
Hard Drive 500 GB - Serial ATA-150 - 7200 rpm
Optical Storage
Type DVD±RW (±R DL) / DVD-RAM
Disc Labeling Technology LightScribe Technology
Card Reader
Type 5 in 1 card reader
Supported Flash Memory Cards SD Memory Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card
Display
Display Type 17.3" TFT
LCD Backlight Technology LED backlight
Max Resolution 1600 x 900
Widescreen Display Yes
Features BrightView
Video
Graphics Processor / Vendor ATI Mobility Radeon HD 4650
Video Memory 1024 MB
Total Available Graphics Memory 2815 MB
Audio
Audio Output Sound card
Compliant Standards SRS Premium Sound
Features Altec Lansing speakers
Audio Input Microphone
Notebook Camera
Camera Type Integrated
Input Device(s)
Type Keyboard, touchpad
Telecom
Modem Fax / modem
Max Transfer Rate 56 Kbps
Networking
Networking Network adapter
Wireless LAN Supported Yes
Wireless NIC Intel WiFi Link 5100
HP DV7-2270us
Cache Memory
Type L2 cache
Installed Size 6 MB
RAM
Storage Controller
Type Serial ATA
Storage
Optical Storage
Card Reader
Display
Features BrightView
Video
Audio
Notebook Camera
Input Device(s)
Telecom
Modem Fax / modem
Networking
Posted Sun 17 Apr 11 @ 9:12 pm
@ Voodoo
Have you tried the registry tool? That fixed my freeze problem awhile back. Also make sure you download the latest version of the registry tool.
Hope this helps
Hope this helps
Posted Mon 18 Apr 11 @ 2:05 am
Posted Mon 18 Apr 11 @ 2:07 am
DJbojett, you have in VideoMemMaxUse=232. Did you put that value in, and what does the value mean?
Posted Mon 18 Apr 11 @ 12:48 pm
I was told to put that value in sometime ago in the forums. When I set that to 232 my video freeze stopped. I have a 1 gig video card and i believe 232 is like a 1/4 of the video card.
Posted Mon 18 Apr 11 @ 1:56 pm
I will try this tool and see if I notice any difference. I am not having any issues, so it may cause some.
Posted Tue 19 Apr 11 @ 12:37 am
hey if its not broke don't fix it lol
Posted Tue 19 Apr 11 @ 2:20 pm
