So My first Question is if i can use Time coded vinyls on Virtual DJ pro 7 or will i have to get Virtual Vinyl. The second question I have is if i have Virtual Vinyl and want to upgrade to virtual DJ pro dose that mean i get the discount on VDJ pro but i cant use Virtual Vinyl anymore or can i use both. and the last thing i need is if you guys can give an analysis in the difference of VDJ pro and Virtual Vinyl. I know these may be a lot of question but it would really help me and also others with the same questions...
Thank you so much!!!! :-)
Posted Sat 16 Apr 11 @ 11:55 am
Oh and i also forgot. is there anything special i need to do for time coded vinyls to work or can i just get the VDJ pro, Virtual vinyl and time coded vinyls and thats it???
Thanks again!!!
Thanks again!!!
Posted Sat 16 Apr 11 @ 12:00 pm
yes you can use the timecode option with vdj pro, u just need some form of soundcard/hardware (virtual vinyl could be one of them, other options range from sl1, sl3 to rmx, vms4 and such) that will allow you to connect a dvs with ur vdj pro.
i think the virtual vinyl is the pro version, i could be wrong, and once you get pro u dont need the virtual vinyl version, think of pro as the sum of ALL versions out there (LE, virtual vinyl, CUE, u name it).
this is the basic comparison, although virtual vinyl is not in it: https://virtualdj.com/products/comparison.html
besides VDJ pro, Virtual vinyl and time coded vinyls, you will need turntables, an external mixer, rca cables, speakers and a laptop.
Posted Mon 18 Apr 11 @ 7:15 pm
Thanks for the help! Are there any timecoded setup that are good but cheap that you may know of. Oh I have the RMX wich ide use like a sound card and mixer and im geting VDJ pro. i would particularly like a CDJ setup not vinyl because i have small space...
THANKS GUYS!!!
THANKS GUYS!!!
Posted Tue 19 Apr 11 @ 7:57 pm
you can run it with the rmx, thats a good config
Posted Tue 19 Apr 11 @ 7:58 pm
