It works fine on my Mac but I've just added the definition and mapping to a windows machine and I get this piano chiming noise (sounds like a MIDI voice). This only happens when VDJ is running and the sound. Telling it not to look for MIDI controllers solves the problem.
Problem is I want to use the Controller and this loop in the background seems to be hogging the system a little.
Only reason I need to do this is my Mac had a little accident this week and I need a new backup solution until it is repaired.
Gigging tomorrow night (Saturday) so hoping for a quick fix.
Thanks in advance as usual.
Ross
Ross
Posted Fri 15 Apr 11 @ 10:46 am
This will be because you are using a definition that has no identification methods specified for VirtualDJ to be able to identify the controller (sysexid, drivername or vid/pid)
A definition like this will be applied to all unrecognised MIDI devices, including the MIDI synthesizer of your sound card, if it has one. The LED's turning on/off will send MIDI notes, triggering the appropriate musical notes.
The solution is either to add an appropriate method of identification to the definition (See https://virtualdj.com/wiki/ControllerDefinitionMIDI.html ) or mute the MIDI output of your sound card in the Windows control panel.
Posted Fri 15 Apr 11 @ 4:35 pm
Do the VirtualDJ have a piano ?
Posted Mon 04 Jun 12 @ 1:37 pm
No.
Keith
Keith
Posted Mon 04 Jun 12 @ 1:43 pm
