I am using a Macbook Pro osx 10.6.4
VDJ 7.0.2
I want to use timecode CD's with PIONEER cdj1000'S.
Can anybody advise a good soundcard to use, will the Rane SL2 work with this, I have tried the Maya 44 but failed
VDJ 7.0.2
Posted Sun 10 Apr 11 @ 7:22 am
The NI Audio 10 is one of the best interfaces on the market. Be prepared to spend some money though.
Check it out.
AC
Check it out.
AC
Posted Sun 10 Apr 11 @ 3:44 pm
the maya should work, however the hercules deejay trim will also sort you out.
Posted Mon 11 Apr 11 @ 6:46 am
