Hi all,
I've recently run into an issue with function mapping. I recently bought and set up an Akai APC20, and I've been mapping the functions with VirtualDJ...However I've run into a problem. I've tried to map the function "Effect 'Flanger' Active" (Or any other effect) to one of the buttons on my APC20. The function works...but it doesn't specify which deck to play the effect on, and for some reason, it always plays on just Deck B. Is there code for VirtualDJ that will allow me to specify which deck to play an effect on? Thanks.
-Mike Electro
-Mike Electro
Posted Thu 07 Apr 11 @ 7:24 pm
deck 2 should do it, you really should read the scripting wiki though, and register you version of vdj so you can get upgrades, plugins and skins.
It needs to look like:
deck 2 effect 'flanger' active
Posted Thu 07 Apr 11 @ 9:46 pm
