I am having trouble setting up my sound card.
I am using:
Macbook Pro OSX 10.6.4
Virtual DJ Pro 7
Maya 44 USB Soundcard
I have followed youtube videos but had no success...
This is what i have configured:
Audio Midi setup: Aggregate Device 4in/4out Maya44 USB
Virtual DJ Config: Inputs None, Outputs external mixer, Sound Card 4 out aggregate device
Any thing i have done wrong???
I am using:
Virtual DJ Pro 7
Posted Thu 07 Apr 11 @ 8:40 am
I potentially may be running into the same issue....Macbook Pro VDJ 7 and in need of a reliable soundcard. Was considering Maya 44 as well....using Timecode vinyl...can anyone help?!?
Posted Mon 04 Jul 11 @ 12:49 pm
@stuartlee where you able to find any sort of solution online? Saw all of triple9's videos but still no fix..and now Im an owner of this maya 44...got it working to a certain degree (only left deck plays) however the sound is garbage right now and not sure why
if ANYONE can help it would be GREATLY appreciated!!!
Posted Sat 30 Jul 11 @ 7:17 pm
Has anyone had any luck with this?
I have a macbook pro running 10.9.2, maya 44 soundcard and timecode vinyls on a pair of 1210s with virtual dj 7. I have downloaded the driver from esi.
I cannot get any response on VDJ when I go into timecode config, have tried all modes etc. Silence no matter what I do.
Settings:
INPUT and OUTPUT is set to 44100.0 Hz and 4ch-16 bit in Audio MIDI setup. Have tried changing input/output volumes between 0 and 1...
VDJ - Input timecodes: chan 1&2
Outputs: external mixer
Soundcard: maya 44 soundcard
Works fine on a friends windows laptop, cannot get anything to work on my mac. If anyone can shed any light much appreciated.
Settings:
Posted Thu 08 May 14 @ 11:55 am
Hi,
you need to install the latest available build from your account side.
To get the latest one, you simple need to register your Pro Full / Infinity license key under your account.
https://virtualdj.com/users/edit.html
After that you can download your actual VDJ copy from there.
If you didn't own a vaild serial, you can buy it here:
https://virtualdj.com/buy/
https://virtualdj.com/wiki/Forum%20Rules.html
If you still have problems after that all, please open a new topic and insert there all further needed details :-)
Thank you for understanding
closed
Quote :
Do not bump an old topic that is more than 1 year old. Old topics may no-longer be relevant to the current version of the software. Please open your own new topic in the appropriate forum.
closed
Posted Fri 09 May 14 @ 2:17 am
