Guardate un po' cosa propone Numark per il Musik-Messe :
•Complete system with CD/MP3/USB decks, mixer, computer audio and MIDI interface, and iPad core MIDI and audio support
•MIDI integration of decks and the mixer for controlling both computer software and iPad apps
•iPad supported by Algoriddum DJAY
•Two-deck Native Instruments Traktor LE software is included in Europe
•Four-deck Virtual DJ software is included in North and South America
•Play from CDs, MP3 CDs, USB flash drives, iPad, computers, and external inputs
•Four-channel mixer with EQ/rotary kills, replaceable crossfader, and MIDI control
•USB MIDI/AUDIO computer interface for software control and audio streaming
•Inputs: Two Mic (XLR and 1/4"), Four Aux (RCA stereo pairs), iPad Connector, Computer (USB, stereo)
•Outputs (all stereo): Main (balanced XLR & RCA), Booth (RCA), Record (RCA), Deck 1 (RCA), Deck 2 (RCA), Cue (1/8” & 1/4”)
•Beat-synced DSP effects with wet-dry fader: chop, echo, filter, flanger, pan, phaser
•Smooth, fast, slot-loading drives with large, touch-sensitive illuminated platters
•Control MIDI software, with no timecode needed, via USB
•CD direct outputs for use with timecode interfaces
•Adjustable start and stop time for vinyl-like deck performance
•Automatic BPM analyzer and Tap tempo for manual BPM entry
•Slide BPM ±6, 12, 25, and 100% or bend with pitch buttons
•Key Lock holds pitch while you independently manipulate its BPM
•Seamless looping, sampling, and easily accessible hot cues
•Keep time moving forward while you cut or reverse the track using Bleep/Reverse
•Single-track, continuous, and programmable playback
•Fader Start plays the cued track when you move the crossfader
•Two large, backlit displays for BPM, CD/MP3 text tags, and folder navigation
Includes:
•MIXDECK QUAD controller
•Software CD
•Power cord
http://www.numark.com/mixdeckquad
A quanto pare è l'evoluzione di mixdeck, con la possibilità di gestire 4 deck e di farlo anche via MIDI (ricordo che il la parte centrale di mixdeck lavora solo in analogico e non in midi)
Includes:
•Software CD
•Power cord
Posted Wed 06 Apr 11 @ 7:30 am
molto interessante...
Posted Wed 06 Apr 11 @ 7:48 am
significa che devo vendere velocemente la mia a 2 ch prima che si svaluti con l'uscita di questa O_O
Posted Wed 06 Apr 11 @ 7:59 am
bè no dai...certo si svaluterà ma la mixdeck rimane un'ottima console...
Posted Wed 06 Apr 11 @ 8:03 am
sicuramente, ma "superata". cioè.. questa avrà a 4 canali, sarà prbabilmente tutta midi, qualche miglioramento qui e la... se il prezzo non supererà i 900 euro, che senso avrebbe prendere la "vecchia" mixdeck se non ad un prezzo d'occasione?
Comunque vedremo, non verrà di certo rilasciata immediatamente ;)
PS: dovrei venderla comunque per passaggio ad altro sistema... per quello dicevo che mi conviene farlo il più velocemente possibile eheh
Posted Wed 06 Apr 11 @ 8:24 am
bè che sia superiore questo è quasi certo...comunque si in effetti il fatto di essere tutta midi non è male...
Posted Wed 06 Apr 11 @ 8:59 am
Penso che Numark abbia sentito le mie preghiere!!! XD
Pensare che volevo acquistare qualcosa come l'NS6 e collegarci un cdj (che mi necessita durante gli spettacoli) ma con questa ho risolto eliminando anche i collegamenti!
Bene bene... aspettiamo le recensioni... :-)
Posted Wed 06 Apr 11 @ 12:08 pm
Magari chi tornerà dal messe saprà dirci qualcosa in merito: funzionerà pc + iPad contemporaneamente?!?
Posted Wed 06 Apr 11 @ 12:10 pm
abemus video :
Molto probabilmente funzionera' anche con VDJ ;)
Posted Thu 07 Apr 11 @ 4:37 am
