What is the best brand of hard drive to use?
Posted Mon 04 Apr 11 @ 3:23 pm
My preference has been Western Digital and Seagate but make sure you get more than 1 for back up purposes.
Posted Mon 04 Apr 11 @ 4:13 pm
I use a Seagate Free Agent Go, and have an identical as a back-up. It has worked great for me thus far. You will hear people down on Seagate and Western Digital because of failure issues but keep in mind that these are the widest used HDs on the market so therefore they will have an increased sample market equaling more failures.
A bonus is that they are also widely available and don't need to be special ordered.
Posted Mon 04 Apr 11 @ 4:31 pm
Those are the ones I have now a 250g WD and a 500g Seagate and I also have a 150g Buffalo, thay are all 2.0 USB. The Seagate I had for like 2 weeks and I am having problems with my Crates on Serato (I use Serato Crates on VDJ), keep losing the files neva had that problem with my WD. But I have a Macbook Pro and a Sony VAIO both have USB but one has firewire 400 and the other firewire 800....I don't do Videos but probably will do so soon. I jus wanna buy me a TB and use a 500g for my Music so right now I'm lost in the sauce....LOL.
Posted Mon 04 Apr 11 @ 5:17 pm
seagate all the way
Posted Mon 04 Apr 11 @ 6:10 pm
really seagate....maybe i should buy the firewire port
Posted Mon 04 Apr 11 @ 6:34 pm
LaCie Rugged. Hands down. This thing is portable and durable, it is designed with the mobile dj in mind (at least thats the way I use it) haha.
Posted Mon 04 Apr 11 @ 9:48 pm
WD or Hitachi.
Posted Mon 04 Apr 11 @ 11:57 pm
I use LaCie and WD
Posted Tue 05 Apr 11 @ 12:42 am
Mybe the vibration from the bass and people jumping up and down could affect wich hd to buy?
I sometimes have dancing people crash into my dj-table, and is worried about how my hd will tollerate this. Does anybody know if this could damaged the hd?
Posted Tue 05 Apr 11 @ 8:23 am
I have several of these ranging from 500 -2tb they have Panasonic drives in them, supper rugged with all metal cases..
http://www.acomdata.com/app/stx.productdetail.asp?did=21
Posted Tue 05 Apr 11 @ 8:25 am
i use the 1 tb wd passport se. awesome item
Posted Tue 05 Apr 11 @ 5:27 pm
Seagate all the way, but make sure you have a back up to the back up :)
Posted Wed 06 Apr 11 @ 9:03 am
