I am thinkning of buying this set for myself for beggeners will this work to hook up with virtual dj?
http://www.topdjgear.com/gemini-cdj-package.html
Thanks
Thanks
Posted Mon 04 Apr 11 @ 1:47 pm
not sure if it will work with VDJ or not for i never heard of it from anyone, btw why not go for Gemini CDM-3610 or maybe Gemini CDMP-6000? seems far better than the Gemini CD Mix 5.0
Posted Mon 04 Apr 11 @ 2:44 pm
As long as you have an soundcard it will work.
Posted Mon 04 Apr 11 @ 4:20 pm
Sound card, and time codes, and it should work just fine. Why not wait for the Gemini CDJ-700's. They come in with a built in sound card, according to their website, and they can be used in MIDI mode therefore eliminating the need for an external sound card or time codes.
Posted Mon 04 Apr 11 @ 5:59 pm
I Thought you already got your 1st DJ set?!?
https://virtualdj.com/forums/145740/General_Discussion/New_to_Djing_have_some_queastions_please_help__).html
You playing games with us or do you really want help?
Posted Mon 04 Apr 11 @ 6:17 pm
Hello I have the gemini cdmp 6000 and I was wondering if and how can I hook it up to the virtual dj program being about to use all knobs and scratch effects thank you for your time
Posted Sat 21 Jan 12 @ 9:32 pm
Posted Sun 22 Jan 12 @ 10:48 am
