Hi guys...everything about the 4-mx is cool, but im not happy with the response of the scratching.....no matter how you set the buffer size, or buffer watever it doesn't seem to give the real time response that a good scratch requires...Or is there anything im doing wrong or not doing at all that'll give it that real time response...especially when you want to scratch to start a new song while mixing...i like that move but can't seem to get it done....thanks guys...you are appreciated.
Posted Sat 02 Apr 11 @ 1:20 pm
I have ask a rep at Hercules, and that shouldn't be an issue, maybe it might be defective? You might consider contacting Hercules for questions, and Help, could be a driver problem, or a config Issue? If you have not reinstalled, I would reinstall, and see if that might resolve? Good luck!
Posted Sat 02 Apr 11 @ 1:46 pm
Go to this site for Hercules http://www.herculesdjmixroom.com/en-gb/ and/or check your jog sensitivity in your options, along with Performance section in your config area!
Posted Sat 02 Apr 11 @ 4:31 pm
