cant figure out how to record a mix correctly, when i press record and start my mix, while im cueing up my next song in my headphones that seems to be recording with the song thats currently playing. how can i prevent this and only record what comes out of the master output (whateveryone hears, not the dj cueing)???????????
Posted Mon 28 Mar 11 @ 8:31 pm
what u using for hardware?
Posted Tue 29 Mar 11 @ 6:31 pm
2xpioneer cdj 900, MacBook, djm2000
Posted Tue 29 Mar 11 @ 7:01 pm
so what u using for soundcard options?
Posted Tue 29 Mar 11 @ 7:02 pm
Also, having an issue here with similar equipment. I'm using 2 Pioneer CDJ 900's, 1 Pioneer DJM 5000 Mixer & Macbook Pro. I have a RCA to 1/8 cable running from the "record out" on my mixer to the Input on my Macbook. Problem is both of my CD decks are running through the same channel on the outputs. I tried a variety of configurations (some below) and keep having the same issue. Any thoughts? Thx.
Deck 1 - Pioneer CDJ-900
Deck 2 - Aggregate Device
Record Loopback - Built-in Input
Deck 2 - Pioneer CDJ-900
Master - Pioneer CDJ-900
Posted Thu 21 Apr 11 @ 6:53 pm
Posted Sat 28 May 11 @ 2:48 pm
having the same problem ... anyone figured this out?????
If you are using a standard external DJ audio mixer (I.e: Not all-in-one MIDI controller such as Hercules RMX, MixTrack Pro, etc.) then please see https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html
Posted Sat 28 May 11 @ 6:16 pm
