Two questions on using these forums...
1) When I do a search for a keyword and get (for example) 10 thread matches, and then I read one of those matches, how do I go back to my list of 10? If I hit the back arrow, I lose my search, and have to re-enter it again. Am I missing something?
2) I remember being able to be emailed when someone posts a reply to my question... I couldn't find this under my profile settings. How do I set that up?
Posted Sun 27 Mar 11 @ 11:50 pm
1) The back button should work so I don't know what to tell you there.
2) In the upper left while in a thread, in the search bar is a icon of a bell. If you click on it, it will monitor the topic and send you an email when someone replies.
Regards,
AC
Regards,
AC
Posted Mon 28 Mar 11 @ 12:26 am
Question 1, when you hit the back button hit the refresh icon and it'll ask are you sure or something to that effect, not hit yes and it should show your results again. That's how I do it not sure what others do.
Question 2, you should see a bell in the left hand corner up top, click on it and you should get an email when someone post in that thread.
Hope that helps
Huey
Hahaa! AC beat me to it, but yeah what he said, lol!
Hope that helps
Huey
Posted Mon 28 Mar 11 @ 12:27 am
Oh that Huey! A minute and a half sooner and you'd be beating me to the punch!
That should solve both your issues now!
Best of luck,
AC
Best of luck,
AC
Posted Mon 28 Mar 11 @ 12:32 am
