Does anyone has a VMS2? any draw back like the VMS4? which is a better deal VMS2 or Mixtrack Pro?
Posted Sun 27 Mar 11 @ 2:58 pm
I really can't tell you what to buy, both are good entry level controllers. I went with the Mixtrack Pro because I found it for a deal on craigslist. They are so similar that it's scary... I'd advise to see if you can play around with each for a little while and then make your decision. I will tell ya though, you cant go wrong with the mixtrack right now.
Posted Sun 27 Mar 11 @ 9:06 pm
mixtrack pro is good but no gain knob wonder why numark did not add that. vms2 is midi plus analog thats a good thing but no effects control knob. why do they make things incomplete its sad m still confused wht to get until today since im not gonna be buying it always so better invest on something which would last longer :-)
Posted Mon 28 Mar 11 @ 5:51 am
Please keep in mind that these are considered "entry level" controllers. Controllers that are "Pro level" have all the bells and whistles. If you'd like all the buttons and knobs, you will have to spend a little bit more money. As like everything else in life, it's hard to buy a Ferrari on K-Car budget.
Regards,
AC
Regards,
AC
Posted Mon 28 Mar 11 @ 12:08 pm
thats true.
Posted Mon 28 Mar 11 @ 1:57 pm
