I do video DJing for a local band. For the gig that we have tonight I was initially told that input for the monitors at the venue were VGA. Well it was sprung on me a few mins ago that they're in fact RCA, an output on don't have on my laptop. I'm running HDMI and VGA on it right now. I'm pretty sure I need some sort of converter, but I don't know where to even start to look for it. I'm in the North Jersey, Rockland, Westchester area outside NYC if anyone knows of a place to get one.
Posted Fri 25 Mar 11 @ 11:58 am
Radio Shack sells a PC to TV video converter. Runs about $100. One thing tho, you need the Full Pro version of VirtualDJ for full screen video. I believe the full screen option is disabled in all the other versions.
http://www.radioshack.com/product/index.jsp?productId=3709741&retainProdsInSession=1
Posted Fri 25 Mar 11 @ 12:06 pm
Yeah, I have pro... I've run full screen before. Just never ran into a venue that had only rca... I've always had options.
Posted Fri 25 Mar 11 @ 1:39 pm
Just picked it up... thanks a ton for your help!
Posted Fri 25 Mar 11 @ 2:02 pm
If you have a pro license, I would suggest registering it here. Before you toss out the standard "I'm not on the machine that VDJ is installed on blah blah blah" it doesn't make a difference if you are on the computer with VDJ or not. The license is tied to your login. So, if you are running full screen video, many here will assume that you are using a pirated copy of the software. If you ARE using a pirated version, you are really doing a disservice to not only yourself, but to the people who provide for their families by working for Atomix Productions as well rest of the community here.
Posted Fri 25 Mar 11 @ 3:54 pm
