Hello I have the version home 7.0.2 to try with my akiyama sirion, before buying it since it is a lot of money, in order that then I do not like it, well explain to you, if only it me works 10 minutes .... in function virtualdj pro; my problem is that the led of the sirion, do not ignite when you press them, I say that they do not change intensity, Not if this one pressed or this one, good the mappers me there comes one that is Generic ME100, and them of akiyama some happened to me in order that it works with the name akiyama sirion, the bad thing of everything is that it detects to me two the Generic ME100 and the akiyama sirion, I try to erase the generic ME100, but I do not find her since in the folder of mappers only I have the akiyama sirion, and there is no way of erasing the generic ME100, if someone can help me, where and as this mappers to erase, for qeu only me the akiyama sirion works, thanks to all ... one forgot me I have activated to see secret files ... and one does not see any
Posted Tue 22 Mar 11 @ 12:19 pm
