Hey guys, new here. My setup:
- Numark DXM09 (Mixer)
- Behringer UFO202 (sound card)
I want to add a numark ndx400 (cd player)
I know I need to download the mp3, but how do I connect it to the behringer and stl use my mixer? Do i need 2 soundcards?. I want to use my external mixer with ONE ndx400. How can I make it work?
Posted Thu 17 Mar 11 @ 8:59 pm
please?
Posted Thu 17 Mar 11 @ 10:34 pm
You will need a suitable ASIO sound card with 4 inputs and 4 outputs such as Hercules DJ Trim, Native Instruments Audio 4 DJ or ESI Maya44 USB.
Timecode CD's can be created yourself using the file downloadable from https://virtualdj.com/products/timecode/cd.html - Simply use your CD writing software to burn a couple of audio CD's using this file.
VirtualDJ Professional https://virtualdj.com/buy/ is required for timecode use (VirtualDJ Home FREE allows timecode to be tried out for 10 minutes at a time: https://virtualdj.com/download/free.html )
Setup instructions can be found in the user manuals for VirtualDJ: https://virtualdj.com/wiki/PDFManuals.html
NOTE: Your computer needs to meet and preferably exceed the recommended specification on the following page: https://virtualdj.com/products/virtualdj/
Posted Fri 18 Mar 11 @ 6:24 am
So, I can't use my current soundcard? (UFO 202) 1 pair of outputs, and 1 pair of inputs. look at this vid: http://www.youtube.com/watch?v=0NoE4aCU_Cc
He used 1cd player, with my soundcard. When I buy the other NDX400, I could but another soundcard.
Posted Fri 18 Mar 11 @ 12:19 pm
You could use it for a single timecode deck, assuming that it has an ASIO driver (If not, then it is unsuitable, although ASIO4ALL (An ASIO emulator) can be used to work around this - However, this will not give you true low latency ASIO sound - Latency will be high, resulting in poor scratching response and quality.)
Using two identical cards in Pro Advanced Sound Config should be possible, but is not recommended. A good quality all-in-one 4-in/4-out card is strongly recommended for best results (See above.)
Posted Fri 18 Mar 11 @ 1:32 pm
Do you know a cheap soundcard that would do the job??
Posted Sun 20 Mar 11 @ 1:02 pm
MAYA44 USB
Posted Sun 20 Mar 11 @ 1:07 pm
