Just bought last night the console. Before i have the MK4 now i upgraded to 4Mx.
The problem that im having now is when i install the VDJ that comes with the controller it install the program but without the mapper. I already tried to install and uninstall the program but still the same i dont have the mapper.
Any mistake that i made in the installation??
Posted Mon 14 Mar 11 @ 2:59 pm
update the 4mx software.
right click on the dj icon there and click on check for updates
hope this helps
hope this helps
Posted Tue 15 Mar 11 @ 2:05 pm
Thanks! I'll try this one,
Posted Wed 16 Mar 11 @ 2:56 am
VDJ LE doesn't offer the possibility to make changes to the controller configuration. The mapper tab is not available.
The only configuration menu available is for the audio setting.
As for djbojett advice, this will only update the DJ drivers (if you don't already have the latest one). it has nothing to do with VDJ
Posted Wed 16 Mar 11 @ 6:55 am
By the way the Mappers that im talking about is the mappers in the VDJ folder in the windows. When i open the Mapper folder inside the VDJ folder in windows there is no XML file. So it means that there is no mapper for my unit.
Did i understand this wrong or what?
Posted Wed 16 Mar 11 @ 7:42 am
